XTS-2500 "caller ID"
tommul05
OK, new to 2500 CPS, On MTS CPS I go to display and menu and click enable for caller ID, this allows current radio that is being received's ID to momentarily show on the display. I can not find this feature on the XTS-2500 CPS. Anyone familier? Thanks
N4DES
Retired 0598 Czar ÆS Ø
South FL
The Caller ID option needed to be included in the feature/options purchased
with the radio in order for it to work. Can you post your flashcode?
As to where to find it, it's in the Display & Menu area and under PTT ID.
tommul05
The flashcode is 500008-000410-5. Thanks for the help. Can you tell anything by this flashcode?. Tom
grem467
Houston, TX
your radio has the required option to do it.. just need to enable it...
Q806/G806 IMBE / APCO-25 Digital Operation
H14/G114 Digital ID Display <---- MDC/Astro ID Display
H38/G51 Smartzone Operation
Q173/G173 Smartzone OmniLink Operation
2B1 Future System Enhancement
tommul05
I went to the PTT ID tab under Display and Menu, checked the box for ID Display still does not seem to do "caller ID" the box for Scan ID Display is not checked. Number of prefix characters is 4. Any more input on getting the option to enable? I assume from the previous post that the flashcode I provided means the option is on the radio, is this a correct statement?
Again, Thanks to all that are helping. Tom
greenthumb
Colorado DB Administrator
If you're trying to do this in the analog mode, it won't work. Analog talk groups won't show the caller's ID on the XTS-2500 yet. I think that there is a near future release of the firmware that will support it, but will require a 3600 baud "refresh flash" for about $75.00.
As your radio stands right now, however, it will show the caller's ID in the digital mode.
tommul05
ok, our TRS is currently running analog (going partially digital some time in the future), so I assume this is why the option will not work? Is this correct? I am just suprised that out MTS-2000's do caller ID, but the nice,upgraded XTS-2500 will not, that confuses me? New but a step back? Thanks,..Tom any more suggestions.....post 'em.
N4DES
South FL
That is correct, in analog it won't work. I have a bunch
of them and it only works in digital.
I guess I should of asked that first.
greenthumb
Well, your systems' transition to digital in the future has nothing to do with why the feature won't work. The reason it doesn't work is because they didn't add that feature to the radio's firmware....
It is a step backwards - for sure. So is the lack of a hot DTMF keypad in analog trunking for a model III, just to name a few "steps back" they took with the XTS-2500/XTS-5000. Motorola is going to be fixing the lack of these features in newer firmware releases.
