XTS 2500 digital vs analog TG's
tommul05
does it take an advanced system key to program a "digital" system and/or digital TG's into an XTS 2500? and if so, if a digital system and TG's are programmed, can you then use CPS and a "regular" system key to program/change the analog side/system of the unit?
greenthumb
Colorado DB Administrator
It does not take an advanced (hardware) system key to program digital talk groups into an XTS-2500. However, please keep in mind that you should have the proper authorization in order to use a normal (software) system key when programming a radio.
Once a radio is programmed with an advanced (hardware) system key, an advanced (hardware) system key MUST be present for ANY future programming, and this cannot be undone, except at the depot.
