XTS 2500 ERROR
CSFD390
Seneca, SC
Hi all. Just got a hold of some equipment, to program a XTS 2500 unit. I received the correct CPS, a 2 piece programming cable, with USB Attachment, a small blue disc titled, "Driver CD: XP".
Everything has been installed, and I plugged in my cable, correctly hooked up to the radio, hit read on CPS, and got an error, "ERROR:::OPEN RADIO. Also got one in reference to an error, earlier, but cant remember what.... when the USB Is plugged in, it says load new software, so i click on it, and it states, cant locate driver software for USB2.0-SER!
I'm at a loss, as to what to do from here. It is to my understanding, that the small blue disc, was the driver software for the cable. Could it be that im on Vista operating system, and that the disc labeled as XP is an issue?
Any help is appreciated, as i will need to program 40 more of these.....
In the Western US Mountains :)
Well since no one more skilled than me has posted,
I would recommend updating the cable driver !
and Windows XP/Vista could have something to do with it as well,
I have used Windows 7/XP drivers on Windows 8 with no problem
Nasby
Ohio
I've read many threads where folks have trouble with CPS and Vista.
Perhaps using XP will solve your problem?
I have my Astro 25 CPS on a laptop with XP and a serial port programming cable. I have never had a single issue.
CSFD390
Seneca, SC
Ok, I Cannot load my USB 2.0-SER! I have installed the driver CD that came with it, its labeled Driver Cd: XP. It is loaded, and when I plug my USB in, it says new software, and then searches, and says no software found for USB2.0-SER!, unable to load software.
What can I do???? its all that is holding me up at the moment.....
CSFD390
Seneca, SC
Usb 2.0-ser! Xts 2500
Hi, i have posted about an issue with my XTS 2500, Ive installed everything that came with the radio....now saying that it doesn't recognize any software, after i uploaded what i had provided. Help???
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I've merged your two threads together since they both deal with basically the same problem.
KG4INW
Midlothian, VA
What exactly do you mean by two-piece programming cable? Part number or where'd you get it from?
CSFD390
Seneca, SC
But, at this point, all that is stopping me, is the driver for the cable, and I checked on google, and some other reference sights, with no luck in locating a driver for USB2.0-SER! ..... And there isn't a support section on the vendors site.
fireguyastro
delco,pa
XTS2500
Are you trying to use a usb to serial adapter? if so ok try and download the prolific drivers for usb, make sure when you read the radio you have the correct comm port selected, goto start,my computer right click goto properties goto hardware manager goto comm ports and see what comm port you are trying to select, if you need more help contact me @ kb3yqi@gmail.com I have a xts my self and can walk you through this
jim202
New Orleans region
Let me ask this simple question. Have you set the software to say what kind of interface your using? There are 2 choices. one is serial and one is USB. having the software look in the wrong place will kill you each time. I fall into this frequently as I do have both serial and USB cable for different radios. When you go from one to the other, it can cause problems till you figure it out.
I generally start the software and then connect the cable to the radio and then to the computer. If your using a true Motorola USB cable, the software will load the drivers for you. Trying to load an aftermarket cable driver is like rolling the dice.
Good luck.
Jim
CSFD390
Seneca, SC
No, I'm not computer, "savvy", so to say.. but I plugged in my usb, & its like the driver on the blue disc, isn't saving like it says it is, & it dosent ask where I want to save it at. But I will check that tommorow!!
I'm not using a official MOTO Cable...only what was handed to me. I've raised the issue of using aftermarket material....but it has hit deaf ears.
