xts 2500 firmware
D4chaplain
Does anyone know what the xts 2500 firmware would be called in MOL? Im trying to get several 2500s to not transmit on the system. We aquired these from another dept who upgraded so I am not sure what to do.
MTS2000des
5B2_BEE00 Czar
Back in 2015, it was on legacy MOL- but sometime during 2016/2017, it was removed and only added if you opened a case. Last version was R20.50.10. You will need an F/W upgrade refresh key to properly upgrade the codeplug in addition to the firmware. Since these are department radios, this should be done properly and not the hacker/whacker method.
Good luck getting support from MSI. I haven't seen Astro 25 CPS on our MyView ever. It is out there, both CPS and firmware. The hard part would be finding that F/W refresh key. What version HOST are your 2500s at now?
