XTS 2500 issue
I have programmed 2 identical xts 2500 800mhz radios for NAS. Ordered from the same person and are exactly identical. One radio receives perfectly fine and the other one barely receives anything or it just shows the channel with the bad reception broken sound. I made sure to check multiple times before writing the radio. Could this be a software issue or more of an actual radio hardware issue?
hill
Middle River, MD
Hardware issue.
Maybe the radio needs service as radios age they need periodically to be serviced with components changing over time.
Best thing to do is get the radio aligned, since if they aren't right on frequency it will cause havoc with proper decode.
Also if radio is not working perfectly maybe time to return it to the seller
Hardware issue.
Sounds good! I was thinking of taking it somewhere or sending it somewhere to look at the radio itself. Thanks
