XTS 2500 Mute
jtech48
OVB
I recently added a couple more channels to the radio as you normally would but now if i tx on my 5000 on the same simplex channel the red led light will flash but i wont hear anything. Only until i tx on the 2500 then tx shortly after on the 5000 do I hear the sound come through. The radios are not next to each other when i test them they are about 5 feet apart
W2NJS
Washington DC
Assuming you do not have a CTCSS or DPL mismatch, or a frequency mismatch, the transmitting radio is simply overloading the front end of the receiver on the other radio.
jtech48
OVB
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.6; en-us; DROID RAZR 4G Build/6.5.1-167_DHD-14_M3-8) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
The pl's are the same I just checked, and even tried it csq on TX/RX. After you said that I tried it again farther away at least 20 feet outside and still the same. Radio will only unmute receive audio after I key up and receives shortly after but after not receiving for sometime it will mute again. I forgot to mention this is only on non-astro, on astro i receive fine
maxkelley
FN13GF
Are these radios operating on a repeater, or simplex? If they're on a repeater, the transmitting radio is desensing the receiver of the other radio such that it cannot hear the output of the repeater, and therefore you can't hear the radio you're talking on. If that makes sense.
evfd1625
Indiana
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.6; en-us; DROID RAZR Build/6.5.1-167_DHD-14_M3-8) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
You don't have a quick call system set up with an auto reset timer do you? I think they UN mute after tx, then if they have the timer will revert back to the and setting after it expires.
jtech48
OVB
No, i completely forgot to mention that the 1st zone that has this issue uses MDC signaling. The frequencies are simplex-talkaround only, not on a repeater
jtech48
OVB
Solved
It was the Unmute Type in the MDC tab in the personality was set to "And" and it should be set to "Or", i changed it and tested it like that on all channels that use the personality and it now works. The tx opt dev is set to 2.5 khz and t/a dev to 5.0 khz with channel spacing at 12.5khz and also tried it at 25.0 khz and worked with all options whether it was 1 foot away from the other radio or 50 feet away
