xts 2500 question (scan problem)
army_scanner
Port Lavaca Texas
i have a xts 2500 unsure what model. new to the radio world. the xts 2500 has a display and six buttons not a full key pad on the front. the radio scans convitional freq. my question is there any way change what freq. that the xts 2500 scans. i have tried different things but nothing seems to work. anything will help thanks.
Astro25
Chicagoland
If you find that you can't edit the scan list via the front of the radio, then you'd need to read the radio in CPS (The software needed to program the radio, current is R12.x) and then edit it in the software.
rescue161
KE4FHH
Hubert, NC
You would only be able to change the scan list if the original programmer allowed you to do so. If they set a "Fixed" scan list, then there is nothing you can do, short of reprogramming the radio with "Operator Select" enabled.
NeFire242
Nebraska
Depends on how it is programmed, you may not have a user-selectable scan list.
Liverdog
...Should have a soft key labeled "PROG". Press that, then press "SCAN". From there, edit the scan list, if the menu items are available.
PROG and SCAN are menu items that are added in cps. If they are not there, then they'll have to be programmed through cps to be visable.
