An "S" split (450-512) unit should, in most cases, operate down to 440MHz just fine, without the need of any fine-tuning. Most Astro/Astro25 radios can perform +/- 10MHz of the rated band-split without serious degradation in signal quality.
As was mentioned above, you will need to hex edit the CPS to allow programming out-of-band.
