XTS-2500 Scanning
zackmagee
Bethpage, NY (Long Island)
Hi,
My department uses XTS-2500s. Is there a way, without modifying the programming, to scan a select 3 or 4 frequencies instead of the whole bank?
Thanks,
Zack Magee
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Press and hold the Scan button to see if Operator Selectable channels is enabled. If so, it's just a case of deleting what you don't want and enabling what you do want.
If it's not enabled, then you'll have to have the radio reprogrammed.
msingewald
Norwalk, CT
If there is a button programmed for nuisance delete, you could use that to eliminate channels as they become active.
Sent from my iPad using Tapatalk
