XTS 2500i 800 MHZ FPP
nperuta96
ct
Hello,
I have an XTS 2500I 800 MHZ model 3. I bought it used off ebay, i was wondering if its possible to activate FPP on this. i know that the XTS 2500 line has been discontinued for some time. i'm not sure if they are end of life yet. but if its possible that would be great!
Thanks in advance and i l ook forward to all the replys
Will001
SC
Does it have Federal Gov’t or FCC FPP in the flashcode? If it does, then it can be enabled in the software.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Yes but only for conventional channels.
That is the only thing it will work for. You can't program or modify radio-wide programming or anything in the trunking world with FPP.
Also if it is the FCC version you will need the side dongle to allow FPP to show as a menu selection.
nperuta96
ct
thanks for all the replies. Based on the feedback im getting it seems like an idea, ill ask my Motorola friend if hes able to flash it to Do FPP
thanks!
N4KVE
PALM BEACH, FLORIDA
Unless it’s an old FW 9 radio, it can not have trunking, & FPP in the same radio. So if you do not need trunking, it can be flashed for FPP. However, if you need trunking, you can forget about FPP.
