XTS 2500I
716polarbear
Buffalo N Y
I got my Motorloa XTS 2500I but can any tell me how to get it to connect to the repeater mode! The Icon for direct is on some channels. I need it to hit the repeater in my jurisdiction! Any help with the FPP would be great! Hope not a software issue! Thanks!
Motoman55
1FC
If it's has the FPP option you have to program the transmit and receive frequencies and the correct PL or DPL in. What department and channel are you trying to program? I'm in Rochester but very knowledgable with Erie County.
mikewazowski
Staff member
Central Ontario
When you're in the CPS checking your programming, assign a switch, button or menu item to that function.
rjk_165
Usually a side key is assigned to that, or the A/B/C switch which I believe the XTS2500I has.
kb2ztx
South West Virginia
Looks like it is programmed incorrectly. In the programming software what does it show in the personalities ? The only time that will show up is when it is a simplex channel. What version CPS are you using ?
716polarbear
Buffalo N Y
The Icon doesn't show up on all repeater Channels, Also nothing found in Menu. Need software for the unit which I have not obtained yet! Included with the software would need cabls and something called a RIB box! Anyone no where I can get these devices? Thank You again! B Safe guy's.
mikewazowski
Staff member
Central Ontario
You don't need a RIB, just a cable. Software is available only from Motorola.
If the icon is not showing up on the other repeater channels, chances are you've got something wrong with the programming for that channel.
