XTS 3000 Battery
N1SQB
Somewhere On Earth
Im in need for a new battery for my XTS 3000.
With the different choices out there, what battery do you guys recommend buying?
I need to have the radio on for about 8 -10 hours.
Manny
Skypilot007
Medford, NJ
I also prefer the hi capacity 4000+ mah lithium batteries. They're a bit pricy but well worth it. If you ever upgrade to a XTS5000 you can keep your battery and use it on that.
N4KVE
PALM BEACH, FLORIDA
Remember, if you buy a LiOn battery, you will need to use the Impres, or tri chem charger, as most chargers are only Nicad, or Nimh. The above mentioned chargers do LiOn too. If you are using the radio for a hobby, & not public safety, you could save big bucks by buying an Empire BLI-6034, 4200 ma LiOn battery. Lasts as long as the real deal, & was much less $. Perfect fit on the radio too.
N1SQB
Somewhere On Earth
Thanks for the reply guys. I went with the suggested 4500mah LiOn battery. Will be picking up a tri chem charger...
Manny
N1SQB
Somewhere On Earth
Update:
4500 mah LiOn battery finally arrived. It has been charging for well over an hour now on the tri-chem rapid charger. How long should it take? It's brand new. Charger works well and fast on all other batteries.
Manny
FFPM571
The Mid South
Leave it til it turns green..The initial charge is most important to get the full capacity it may take a while as that is pretty much the largest battery made
ME801
NV
I've seen Moto batteries take all night for the first charge on an Impress charger. Let it sit as long as it needs, it's the first charge and as FFPM says the most important (been using Moto batteries for 20 + years).
N1SQB
Somewhere On Earth
Took almost the entire night but I just let it be as you guys suggested. Now, 7:00am, I'm on my bus for my 10 hour shift. Let's see how long I get. I know there is always a break in period.
Manny
N1SQB
Somewhere On Earth
Noon time: Battery was EXTREMELY hot and so was the back plate of the radio. Had to take it out, let it cool and restart. Display was out. Once it cooled, the radio was back in action. Wonder what is up with that?
I thought it was that I had it sitting on top of a candy wrapper by accident that was lined with aluminum foil. Lol...
Manny
