Xts 3000 cloning question ?
surfsup28
Sydney, Australia
When trying to clone from a different radio the CPS wont allow it, saying it is a different serial number..is their anyway of changing the serial number ?
jim202
New Orleans region
Are you sure it says serial number and not the model number? If you try to clone a radio with a different model number, it won't let you.
RKG
Boston, MA
If you try to "clone" a radio by trying a simple "write radio" to the target, you will get the "wrong serial number" error. Cloning, to the extent permitted by CPS, must be attempted via the Tools-Clone menu.
surfsup28
Sydney, Australia
Umm ok thanks guys, yep i found that the clone can be done i think with the clone feature..but presents me with a new problem...i then get error " this problem cany occur until every trunking system in memory has a corresponding system key"..ill figure it out i guess but, maybe someone here might be able to help me.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If you are cloning from a radio that has trunking, you need a system key for each system.
JFM1962
Cloning
So how did you overcome the "serial number" thingy when trying to clone?
and the system key problem?
Be interested in finding out.
merry xmas guys
RyanRox099
Tampa, FL
To change a serial number you'll need a Motorola lab software. Which are not easy to find, they are meant to exist only in Motorola's depot. You shouldn't have to change a serial number, you can clone a radio if it has the same model number.
As for the system key you will not be will to make any trunking changes in the CPS without a valid system key. Which only the system admin's have. There are ways to generate your own system key. if you really want to do some more research on the subject, you should check out batlabs.com.
surfsup28
Sydney, Australia
xts 3000 cloning
When trying to clone the radio i did use the clone feature, u are able to keep the radios serial number and you can still transfer all the rest of the data to the new radio. As for the sytem keys no luck on that one. But all is not lost , as the xts3000 is still a great radio.
