XTS 3000 Flashcode ?
patrickyork
Could anyone tell me if the following flash code would allow for conventional programming in both analog and digital? I don't understand how the whole flash code thing works.
100008-000000-0
Q806/G806 IMBE / APCO-25 Digital Operation
H38/G51 Smartzone Operation
Thanks.
Patrick
W2NJS
Washington DC
Yes, that flashcode on an XTS3K will do both analog and P25.
Check out flashcodes at:
akardam.net Motorola Flashcode Decoder R04.00.02
There are 13 digits in the Motorola flashcode scheme. Each position can have none, one, or more features. The first digit in your code, which is a 1, translates to P25 capability. If the first digit were a 5 it would be the result of a 1, which you know about, and a 4, which means enhanced digital display.
Hope this helps and and answers your question.
patrickyork
Thanks for the reply! Just wanted to make sure my radio works on both p25 and analog conventional channels before I took it to be programmed. Now I know it will. Thanks for the link as well. Very helpful!
Cheers.
Patrick
