XTS 3000 lockout..
MPSMP
Minneapolis
Does anyone know if you can lockout a talkgroup on this radio from the keypad on the front of the radio? What I mean is when the radio is scanning and stops on a certain talkgroup that you don't wanna listen to can it be locked out?
K4RMN
Nuisance delete. When the radio stops on the talkgroup you don't want to listen to, press the button programmed as that. It will then stop listening to that talkgroup, resume scanning, and skip over that talkgroup until the next time you toggle your scan off and on.
ME801
NV
You'll have to have the CPS to program a button for nuisance delete. One agency close to me uses the orange (normally emergency button) since they don't have an emergency system programmed.
MPSMP
Minneapolis
Thanks for the info. Beside a temp lockout is there a permanent way to lock out a talkgroup from the keypad or does that also vary from radio to radio
exkalibur
York, Ontario
If your radio has the ability to edit the scan list, yes. You can edit the list and delete the talkgroup you want to not scan. If it isn't enabled, you'd need to assign a menu feature or switch.
