XTS 3000 P25 Conventional Question
Charlie1068
Houston, TX
I'm looking into to purchasing an XTS 3000 and programming it for P25 Conventional operations. Will this radio have the issue of affiliation like it does when it comes to using these radios on a P25 trunking system.
wgbecks
NE Wisconsin
The XTS3000 only supported P25 9600 baud trunking on 800 MHz models, and only with one specific firmware release. The XTS3000 should work fine for P25 conventional.
Skypilot007
Medford, NJ
No affiliation with conventional use. You only have to worry about affiliation when doing non-affiliate trunk scan programming.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Make sure the XTS3000 you purchase does not have analog only firmware. Also, the CPS will only operate correctly under a 32 bit operating system.
