Xts 3000 power level
dank130
toledo,oh
I have a motorola xts 3000 model 2. Im trying to figure out how to adjust the power level. Is it something i can do from the radios keypad or does it need to be done via programming cable
jhal94
Pinellas County, Florida
Use the arrows to navigate the display menu, if there is no PWR option available there or on a softkey then you will need to assign a softkey or display item in the CPS.
FFPM571
The Mid South
Low is 1 w high is 5 w depending on the radio band that is a softkey that can be programmed. If you want to change or tweak the wattage and try to boost it that has to be done in tuner and that is tricky to do without a service monitor as you can very well burn up the PA if done wrong.
kayfox
The CPS is NLA (No Longer Available), you will have to locate it somewhere on the internet. Look for "ASTRO Saber & XTS3000 CPS R05.03.00" and you will find it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Xts 3000
Please do not ask for it here. You'll find a stickied thread at the top of the forum regarding copyrighted software.
jaspence
Michigan
xts3000
If you do get the software, be prepared for a learning curve that is far above the average amateur radio. If you haven't created a code plug using software before, this is not a program to teach you the basics.
N4KVE
PALM BEACH, FLORIDA
I always use position "B" on the A B C switch for low power. Much quicker than having to navigate through the menu.
mm
oregon
depending on what cable you purchased, aftermarket or original, you may also need a RIB to connect between your computer and the programming cable.
dank130
toledo,oh
I ordered the cable and rib box. Just waiting to get them. The last thing i will ask about software is, does it matter what operating system i have on my computer. Right i have a desktop with windows 98 and a laptop with vista
jhal94
Both of those will work as long as they have a serial port. I personally use a Thinkpad T61 w/dock and windows vista for everything. I used to use a 2595CDT with win98/2000 before that for programming. Now, if you ever get into Astro25 for XTS5000's and XTS2500's then you will need at least XP, it will not install under 98
