XTS 3000 Quick Call II help
Rconk312
Sayreville NJ
Hello I purchased a Motorola XTS 3000 UHF radio. I need to have quick call II available on the radio. I thought this was standard on the XTS but when i programmed the radio there was no option to do Quick Call II. Is this a firmware option that i need to have changed or is it a flash code that needs to be changed ?
Rconk312
Sayreville NJ
Ok so does the 2500 or 5000 ? if so what programing software do they use and is that a standard feature or is it built into the flashcode ?
bezking
On the Road
The 2500 and 5000 do support it as long as they have higher than a certain firmware version (I think it's R08 or higher). If you have modern firmware, it's a standard feature. The XTS2500/XTS5000 use the Astro25 Portable software, which is not the same software that's used to program the XTS3000/Astro Saber.
