Xts 3000 vs 2500 and 5000
GearJammersc
SC
I know this has been discussed before in the past . There really any difference in havening a 3000 on a P25 vs the 2500 or 5000? I hear that a 3000 not recombined on a p25 trunking system with some current 2500s and 5000s are still in operation. There any reason why a 3000 would not work properly on a phase 1 system. Even with the correct firmware on the radio.
n3obl
Ø
PA
Better DSP with 2500/5000 vs 3000. But the best reason of all is what your system admin allows on system as most are requiring newer radios like APX.
GearJammersc
SC
That's all true,but the 3000 with the 9600 baud firmware 6.72 i believe will still operate on a phase1 system with other xts radios on the system reliable? As long as the alightment and all has been done?
sefrischling
New London, CT
I used an XTS3000 on a P25 Phase 1 Harris system every day for about three years, without any issues. I had the only two Motorola radios on the system, never had any issues. The other radio, an XTS2500 never seemed to get used, not for any reason other than I had four XTS3000 batteries and only one 2500 battery.
But P25 Phase 1 is an open system, it can be a Moto, Harris, Kenwood system, doesn't matter what radio you use with it if it is programmed properly. You will need the correct firmware however to get the XTS3000 to work on the system.
MTS2000des
5B2_BEE00 Czar
The 3000 is an ancient, 20 year old platform. The fact that MSI could even get 9600 baud trunking to actually work with a mere 1MB of RAM for the radio O/S is surprising.
I run a 7.16 system and have put a 3000 on the system, just to show someone it does work, including failsoft, selective inhibit both in live and passive, and it did work. That being said, even with the 6.72 HOST and (most current) DSP (which is now 12 years old), it still sounds like crap and 5000 on it's worst day with early HOST/DSP 5.xx sounds better.
As someone else said, it's what the admin allow.
GearJammersc
SC
Thanks for all the informative information. I do remember the 3000 on the 3600 Baud system on P25 sounded like pure crap. I recall I heard one years ago on a 9600baud system wasn't no where near as bad. When its all said and done the new APX radios will be discounted for something new. That's how Motorola is.
GearJammersc
SC
Got a 3000 yesterday model 3. I had one in the past and it sounds like i remember. The audio not bad for say some people have alot of bass to there audio.Then you have some that bout blow you out the room. Yes by far the 2500 audio is smoother.The 3000 is better than nothing. Now i have a 3000 along with a 2500. Lol
