XTS 3000 Won't Receive
peelscan111
I have a xts 3000 Model 1 that no longer receives.
can anyone tell me what parts I may need to replace for that part of the radio.
or any other thoughts on it.
PeterGV
K1PGV
Mont Vernon, NH
Well, since you didn't mention it, I have to ask... Are you sure the battery is charged? Are you sure about the programming? Does it not receive AT ALL, even in the presence of a strong signal with correct PL on frequency?
For an XTS-3000 Model 1, I'd suggest it'd probably be cheaper at this point to replace it than to fix it.
Peter
K1PGV
JoeyC
Senior Member
San Diego, CA
LOL. Like a patient coming to a doctor that says "I'm sick, cure me" you have LOTS more information to shell out before anyone can tell you what is wrong with your radio.
peelscan111
LoL, just opening up the discussion.
k I have used 3 differnt codeplugs that currently work on 3 other radios.. programming issue can be ruled out based on that.
the battery is charged there is an antenna lol, and its within range of the signal. the radio seems to tx just fine but its dead on the receive end.
hope that clears up a few thing.
K6CRB
Does the channels have a rx tone? Some repeaters do not pass pl tones to rx. Does the red light come on when the other station is transmiting
Chet
K6CRB
FFPM571
Nashvillle
is that the same radio that you counldnt get to read? If so I bet some of the settings in the alignment are hosed. You should have it aligned by someone with a service monitor.
