XTS 3000 won't scan ?
fyrebuff2
I have an XTS 300 model III and can not get it to scan , as I am new to the programming part does anyone have any ideas that may help ???
buddrousa
Not having programmed one of those but most radios want you to.
#1 Make a scan list
#2 assign a programmed channel to a scan list
#3 assign a button to a scan list
#4 some radios allow you to make more than one scan list
#5 then you have to assign a button to change scan list
I hope this can point you in the right direction until you find a user that has programmed one of these before.
clbsquared
Isle of Wight County
What specifically are you trying to scan? Conventional channels? Under your personality assignment you need to select a scan list for the personality to be assigned to. It's the tab listed as "Scan" in the conventional personality. Therefore, you need to set up a scan list and a zone channel assignment. There are other things that need to be done as buddrousa pointed out.
Sent from my HTC One A9 using Tapatalk
fyrebuff2
SCAN
Thank you for the responses , here is the story , Motorola XTS 3000 radio is programmed however when i turn the scan on selector to scan it will scan for 2 or 3 seconds and then an alert tone pings and it will no longer scan although the scan icon is still lit it will only receive the channel it is locked on . the personality is set to conventional and all settings appear normal { I am inexperienced on the programming } any help would be great thanks
mathkukoo
From what experience I have, it sounds like you have a priority alert set on the scan, and it is detecting traffic. Are you sure there are multiple members set in the scan list? Do you have them added to the scan list both under scanning and on the scan option for the specific frequencies you are looking to scan?
fyrebuff2
Thank you it sounds as if you may be correct the red light flashes continuously so i am gonna assume that is the issue ..and try and remedy it
