XTS 5000 Astro ID Alias
jtech48
OVB
Hello everyone, im trying to program my xts 5000 to show text on the display under certain id's, i already created an astro call list with the id number and next to them put the text, but after writing it to the radio whenever any id that's on the list comes up, its still just the id, no text. I don't now exactly which option should be enabled to make this work, i went into the personality and under astro call selected call alert decode, selective call decode and on the astro call id list i selected '1' which is the list that has all the aliases for the id's
Thank You
jtech48
OVB
Yes, My Flashcode is 5000080004864
Q806: ASTRO IMBE Digital Operation
H14: Enhanced Digital ID Display
H38: SmartZone Systems Operation
Q173: SmartZone Omnilink MultiZone Operation
Q361: ASTRO 25 9600 Baud Trunking
Q446: Fireground Voice/Channel Announcement
Q667: ADP Software Encryption
When i use mdc signaling on my analog personalities it works and changes the id to the alias name, but its not working on Astro System
MPFD535
NJ
Check under the signaling remember the mcs 2000 had a tab were you could choose id and alias-alias or id.
jtech48
OVB
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; ADR6400L 4G Build/GRJ22) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
The signaling tab only has the tab to choose what you want in the that personality but nothing about alias, the alias stuff i found under astro configuration>astro system but from there im stuck.I don't know what I'm missing, maybe a check box somewhere, and also on the rotary channel selector I know you can program ch 1-16 to be other channels beside 1-16 so if anyone has any insight on that, I will very much appreciate it
jtech48
OVB
OK now I know something is up that I'm missing, I put the same astro call list on my xts 2500 and it works
jtech48
OVB
idle00955 said:
Mine works great on my 2500I
What works ID alias, or rotary channel selector?
jtech48
OVB
Its working on my 2500 too but not on the 5000, could the firmware be old that it doesn't do it?
MPFD535
NJ
Ill check the programming on mine and see what I can find. Ill try and get mine to stop, Does it make a difference if radio is in scan or not? I have seen them not do id when in scan.
jtech48
OVB
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.3; en-us; NookColor Build/IML74K) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Safari/534.30)
Nope, I tried it both scan and not and same result. I believe its the old firmware it has
jtech48
OVB
Radio had been sent to Motorola for firmware update returned today with dsp 17.00.00 and host 16.50.20 and fixed this issue
