XTS 5000 keyload fail
di1uted
A little perplex why this radio won't load a key? I'm trying to load a DES key if it matters.. It's a slightly different flashcode than the others which worked. They all have crypto modules installed. I was thinking maybe the failed had a bad module so I swapped it and still doesn't work
(Radio that failed to load)
(Radio's that work)
EliVonChonk
West Valley, Los Angeles
The options wouldnt keep you from loading a key. Its the difference between single key and multikey and/or OTAR. If you cannot load the key, I would suspect that either that UCM is also bad, or it is AES only and you're trying to load a DES key
trumpetman
Charlotte, NC
I'm betting ADP is turned on by default which means the radio doesn't realize there is a UCM in the radio. It's been a while but I'm fairly certain you have to tell the radio that hardware crypto is enabled before it can be keyloaded.
Giddyuptd
Here and there
3rd button down on side, press it continuous until you hear it go into service mode.
It will cycle through the info and give you the ucm type inside. A radio can be flashed to have multi key etc and not have a ucm.
Only way to know is put it in service mode, see what the ucm type is or if present.
If there and types exist you need check the hardware in the cps not adp.
You will need to load your key with a key loader for example kvl variety or other to load your aes or des key if one isn't present.
Heads up also ensure infinite key retention is checked in cps.
di1uted
Ah, turns out the UCM's I bought were not all 3 algo, that last one was only AES-256
Thanks for the help everyone
