XTS 5000 Power Up Last Channel
jtech48
OVB
Under radio wide settings in cps for xts 5k I selected power up last zone and last channel and write to radio successful, but when I put my radio on channel 26 turn it off and on, the radio goes back to whichever channel the rotary selector is on. I currently only have 1 zone with 206 channels
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
1 zone 200+ channels?!!!!!? How do you manage? I have 128 channels in 10 zones in my work mobile. Albeit one zone has 46 channels the rest have much less some zones have only a few. This is so much easier than having 128 channels all in a row makes it a pain to find a channel I need while driving.
jtech48
OVB
Years working for the same agency, I remember mostly all the channels, especially the ones I use daily
scanner99 said:
I just tested it in my 5k and it worked as it should, if you want to send me your codeplug i would happily take a look at it for you. My email is aro1124@gmail.com
Give me a minute....
scanner99
Los angeles
I am guessing you are using cps 17. Sorry cant read it don't have the newest software. If you have any older codeplug using any other version i can take a look at that.
jtech48
OVB
sorry i dont, i recently got cps and i got it when 17 came out, This is what I have selected
jtech48
OVB
The radios Host 4.80.00 and DSP 4.00.01 could this be the reason why some features are not working on it. Since the most recent DSP/Host is 17
jtech48
OVB
Ive read on batlabs that people were having issues with firmware 16, plus i wouldnt know if its better or smarter to do the update myself
bezking
On the Road
Put the radio into test mode - if you see the word BRAVO, you can upgrade, if you see RAM, I would avoid it.
bezking
On the Road
As long as your radio is an 8MEG, you shouldn't have any issues with R17, which is now the latest firmware.
jtech48
OVB
Yes during the service mode scroll it does say 8 MEG. Is the process the same as when you write to the radio, were you click write to radio and leave it alone til you get the "Write Successful" box?
jtech48
OVB
If the radio has UCM ability but I dont use encryption, Do I need to check the "upgrade ucm" box
bezking
On the Road
If it physically has a UCM installed, whether you use it or not, you should upgrade it. If there's no UCM (even if you have hardware multikey in the flashcode), there's no point in checking the box.
jtech48
OVB
I get an error "The FLASH Upgrade Failed! Cannot Read The FLASHkey Verify The FLASHkey is properly connected" Do i need something else, i downloaded the firmware from motorola. But theres nothing about a flashkey
bezking
On the Road
:lol: I assumed you had one. To flash the firmware, you need a FLASHkey, which is a piece of hardware that plugs into your PC's USB port. You need to buy one before you can do the upgrade.
jtech48
OVB
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; ADR6400L 4G Build/GRJ22) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
How do I go about getting one? Or is it better to send it to MOT to do it?
