XTS-5000 Program issue
usaf27
Ohio
All i need to do is program one radio that is exactly the same as another. The issue im having is that im getting an error "feature set does not match." The software version im running is R16.10. The radios are XTS-5000 Model II. The model numbers are exactly the same. Any ideas? Thanks in advance!
bezking
On the Road
The model numbers may be the same but the FLASHcodes are different. You can't write one radios' codeplug to another if the FLASHcodes are different, hence you are seeing that error.
HTH
davidgcet
i believe you can do an export/import with different flashcodes, but i may be wrong on the XT series. i know it works for APX, just not 100% on XTS/L models.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Easiest way would be to drag and drop between two instances of the astro25 cps.
usaf27
Ohio
The flashcodes were different. I just used another radio that had the same flashcode and it worked. Thanks for the awesome support!
