photoguy2
- Joined
- Apr 3, 2013
- Messages
- 125
So, I've got a M1 that I would like to upgrade to a M3. I have a couple of questions. I understand that the rules prohibit any direct discussion of certain software.
First, What I need is: Housing kit, keypad flex, rubber keypad, and display?
Second. Do I do the hardware first, and then have my friend use his "magic" that makes it a M3 codeplug wise, or the other way around? Or does it matter?
Third: I know with the older displays (C01, C02, and C03), the band matters. I heard somewhere that C04 screens work all on bands. Is that correct?
Fourth: While i'm in there, is it advised to lube the o-ring? Or just clean it, and put it back. I want to do this right, I'm trying to learn as much as get a M3.
Fifth: Is there anything I should be extra careful about? I know the flexes are very brittle, and I have the case tool. I will use a anti-static mat. I know to make sure the O-ring seats right.
Thanks. I've worked on lots of Jedi, and a 3K, I just don't want to mess up a $400 (M1) radio.
Matt
P.S. Please do not turn this into a debate about whether my friend should have certain software, the best color of housing to have (I am working on a pink HT1000 housing though ;-) ), and especially, three pages of whether you need a case tool and name calling, like my last XTS thread degenerated into.
Matt
