XTL/XTS5000 XTS 5000R Connection Error
powahayeagle
Des Moines, IA
I recently received an XTS-5000R and I am trying to program it. I am using Astro 25 portable CPS and cable a RKN4105 programming cable. Whenever I hit read device, I get an error that says "Radio Failed to Acknowledge." A screenshot of it is attached. Radio Error.PNG
Any help on what I am doing wrong would be appreciated.
powahayeagle
Des Moines, IA
Update: I have been looking at cables online and it looks like the pins on my cable might be wrong. Can anyone verify if the pins are in the right place? 20220924_181739-min.jpg
marcotor
I ♥ÆS Ø
Sunny SoCal
Not sure where you got that cable, but the genuine Motorola RKN4015 cable is USB (true USB, no driver hokum needed), and has an additional 25 pin connector for connecting to a service monitor.
powahayeagle
Des Moines, IA
Thank you for confirming my suspicions. I got it from a small business online that I heard from friends was reputable. I reached out to the guy and he confirmed that it was wrong. He said he was going to send me the correct one for free.
n3obl
Ø
PA
aftermarket usb cables have a built in usb-serial adapter. The USB setting in CPS is for motorola OEM cable only.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
The 25-pin connector actually connects to a test box like the RTX4005 for portables up to the Jedi line, and the RLN4460 starting with the Astro25 line. The test box connects to the service monitor.
marcotor
I ♥ÆS Ø
Sunny SoCal
If it was BlueMax49ers or whatever, be mindful their "usb" cable merely has a usb-serial adapter built into the cable. You will need to choose the COM port assigned to the cable, then you can program away :)
MTS2000des
5B2_BEE00 Czar
Look in your Windows device manager and see if there is a "prolific USB to serial" that pops up when you insert the cable. Set your Astro 25 CPS to look for a radio on the port assigned by the Windows device manager.
