XTS-5000R model-2 programming
wcu02mpa
Asheville,NC
I recently picked up an XTS-5000R model-2 700/800 with the following info:
Model: H18UCF9PW6AN
Flash: 5000080004864
I know it is digital P25 but the CPS seems old. I do the system test and it reads:version and DVP 7.00.01
I have CPS up to the new version 16 (I also have some older versions) so can I read and write to this radio with this new of CPS? I just dont want to brick this radio. It also has a secure mode on the concentric switch (screen shows the secure symbol when selected). Can I assume DVP (or some other secure mode) is installed?
Thanks,
Mike
bezking
On the Road
I bet what it said was DSP 7.00.01, not DVP. That number represents the firmware and DSP software versions installed in the radio. 7 is crazy old, the current is 16, so I would get that upgraded.
If you look at the flashcode, you'll see that it has ADP software encryption installed. This doesn't need a UCM, and I bet that's what it is using, since the radio doesn't have the Hardware Multikey option installed in the flashcode.
