XTS GPS Mic not connecting
zacsharpe
Hamlet, NC
I have an XTS2500 and XTS5000, the GPS mic works fine on the XTS5000 sometimes it doesn't connect wen I turn the radio on. I turn it off and said a minute and then turn it on and it connects. Not sure if it's a bad flex in the radio or what.
bk117
Philadelphia
That microphone contains a rechargeable battery. The battery charges when the radio is turned on and the mic is connected. If the microphone has been disconnected for a period of time you may have to leave it connected to the radio with the radio turned on in order to replenish the battery. Depending on how depleted the battery is, this process could take up to eight hours. Try leaving the radio on in the charger with the mic connected for a day. If this doesn't help then your suspicion of the flex may be on point. Good luck with it!
Brad
62Truck
Ordinary Subscriber
Uranus
Brad
It depends on if its a GPS, or a GPS II Mic. I was under the impression with the original GPS mic that it would charge when the radio was placed in the charger with the radio off.
zacsharpe
Hamlet, NC
Okay, so I'm going to try both. Then I will probably be recasting the radio, anyone know if a fresh case comes with a new flex? Thanks, Zac
KG4INW
Midlothian, VA
New housing "kits" with the volume control/channel selector, not just the plastic itself (also available so be careful when ordering) do have all flexes installed.
SD70MAC
NC
Thanks for the battery information. I was issued a new one today and it was giving tone and I didn't know why till I read this . Got it and the radio on the charger now. I had a really old series mic that didn't have GPS and now I have the Commander 2 w/GPS.
Brad
zacsharpe
Hamlet, NC
The mic started acting up again today. I put it back in my 2500 (which the mic works fine on) and I turned the radio on and placed it in the charger. Maybe it will replenish the battery. I have not heard the tone that SD70MAC was talking about.
