XTS3000 xts programing
alexhawkins69
I recently got a XTS3000 and i was wondering what program i would need to program the radio for a fire scanner, i live in shelby county in Indiana. they use a 800mhz frequency and i believe a trunked P25 system.
bclark206
Morristown, IN
I would get a scanner instead. It can be done if you have the equipment but a legitimate radio shop won't program one.
bclark206
Morristown, IN
It would take software from Motorola and a cable for the radio. With that being a radio capable of transmitting I would NOT do it. Could cause safety issues with county system.
wgbecks
NE Wisconsin
And a system key and the proper Flashcode in the radio.
Additionally, the Astro25 Channel ID (Band {Plan) in the XTS3000 is fixed in that there is no user configuration possible. Therefore, the band plan in use on your system would have to match the XTS3000's default or all bets for NAS are off.
INDY72
Indianapolis, IN
With IPSC cracking down on illegal radios on SAFE-T, I would advise you to use an Unication, or an actual scanner.
jaspence
Michigan
It can be programmed to not transmit, but if your software knowledge is limited to Chirp, forget it. Chirp is fine for simple analog radios, but does not work with any digital mode or commercial radio. Motorola is also known to protect their intelluctual property aggressively and it is very expensive
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
Sell the radio and get a scanner. Someone with your knowledge will absolutely mess something up with a trunked radio system if you think that chirp programs an XTS.
Get a nice 800MHZ scanner and call it a day. Put the XTS up on eBay it will save you a major headache.
ma8007
Balt Md
Like others have said there is a steep learning curve to programming a commercial radio for p25 trunking..This is a good start video that I learned from.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Unfortunately that’s not going to be much help since he’s got an xts3000. It’s a good bet that it doesn’t have the right firmware to do P25 trunking.
ma8007
Balt Md
Yeah you are probably right..The 3000 is not the best radio to start with.I think it requires a different CPS then the other XTS radios and it may not have the right flashcode to do what the op wants to do.The concept is still the same explaining nas.After the op sees all the steps he may decide to get a SDR radio like sds100 or a Unication.That probably would be in his best interest.
INDY72
Indianapolis, IN
CHIRP works with lower end radios and DMR. It doesn't do P25, or NXDN that I know of. Motorola ASTRO-25 CPS is not super cheap, and yes is very advanced compared to basic Ham radio CPS.... And if you get pirated copies and get busted using it, you batter have a dream team of lawyers.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Why would he want ASTRO25 CPS for an XTS3000?
Batter up!
jaspence
Michigan
The Anytone radios listed with Chirp are not DMR, just like all the other radios that Chirp does work wuth.
rescue161
KE4FHH
Hubert, NC
Firmware is also not easily changed as you need a specific version to do 9600 P25 and you need a SmartRIB and a service RIB-Radio cable. God help you if you have an old analog only XTS3000. Unication pager is your best, safest option.
com501
Just buy a scanner, this will save you jail time on numerous felonies. Criminal defense lawyers want their money up front.
I_am_Alpha1
Let's suppose for the fun of it...you legally purchase the required setup (i.e., cable and software), get it all installed, configured, and fire it up--BAM!, password enabled. I've come across several big M radios with passwords.
