XTS questions
k8ble
HAM, ATV'ER, MOTOROLER XTS 2500 Q52.Q53. Q811,H02
mn
a question I'm working on a few radio's xts 3000. 2500. 5000.
on the VHF 2500 as I'm entering the freq's numbers for the repeater like 145.290..rx and transmit 144.690. it keeps changing the rec to 150.690.
can't figure out what is going on, I don't see any place that I can change it...any help. in the zone channel assignment. this also has FPP.
The next question on a UHF 2500 with FPP, it is a military radio with encryption, I don't see well with a lot of light which this one didn't
have, so I looked around the internet for a solution and found to change a few resistors I could get the display to light up like normal. well, I tried and lost. so if I can find someone who would try it I'd buy a regular dial pad and try that, I'm not sure what it's supposed to be populated with so does anyone think it would work? The back almost seems blank, but does have a few components on it.
thanks to all the old man here. By the way, the UHF 5000 is working well.
nokones
Sun City West, AZ
Is the radio a Q Band Range radio or a K Band Range radio? What is the 4th character in model number?
There are sellers on eBay selling both used and new Display modules. I just had one replaced in one of my XTS1500 for $70 in labor a couple months ago. I don't remember what I paid for the display module. It wasn't too much.
prcguy
The XTS2500/PRC-153 has very dim backlighting for use with night vision equipment. The keypad also houses the encryption, so if you swap it for a regular 2500 keypad you lose AES encryption. Its best to change the resistors if you have the means.
madrabbitt
NM
i'm pretty certain its doing that because of channel spacing, but let me go grab mine and try it.
madrabbitt
NM
that theory is out the window, no matter what i set the channel spacing to it accepts both your TX and RX frequencies.
k8ble
mn
i tried entering 138,290 to see if it would go to 145.290 no luck keeps going to 150.2900. thanks again group.
k8ble
mn
thanks for the info. i don't have a microscope so need to find someone. i have the resistors but shake to much..lol
k8ble
mn
yes its a Q.
madrabbitt
NM
i thought 2500/5000 XTS VHF were all 136-174.
The 3000's were the ones split between J and K
were the early 2500's (4mb) split as well?
Edit, i checked documentation. All VHF 2500's, AN or BN are K range 136-174
It *may* be a firmware issue
BigLebowski
Piedmont NC
XTS3000's only came in one VHF split, and that split is 136-174. I have programmed countless XTS's of all models and have not come across an issue like the OP is describing. I am thinking some VERY old firmware, very old software, or a mismatch between the two. What version of firmware and software are you using?
@k8ble if you want to send me your codeplug I will take a look at it. PM me.
madrabbitt
NM
i recall a post that had a similar issue, and it turned out to be a old firmware problem.
i think that post was about 5k's, where someone had two of them and one wasnt programming to the same frequency as the other
k8ble
mn
who did it for you..i saw some on eBay and used on to program my 900 ht's a good job and just what i needed, but now I can't find the guy i trust. I found a shop in FLA I sent an to him asking if he could do the resistor swap, but when they read the instructions I sent to them they returned
my money asap and returned my radio, because it wouldn't self-test...
well if anyone knows of a good repair place or person please let me know...thanks
k8ble
mn
rgr
k8ble
mn
how do i PM u?
k8ble
mn
trying to send plugg
  • Voice_File_Log.txt
madrabbitt
NM
I was talking to an old coworker about how i remembered that we had bought some VHF radios in the wrong bandsplit, and i asked "i swear those were XTS3k's."
He looked at me like i was an idiot and reminded me that was 2001-2002 and we were using hand-me-down P200's and HT600's at the time.
So yeah, i both mis-remembered that, and probably shows how long i've been doing this.
merlin
DN32su
See if you have talkaround enabled, uncheck it if it is.
You will need to do that for each repeater channel.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Can't remember if XTS3000's had Frequency Picklists as an option but check the top level menus and make sure that's disabled.
