xts radio not to tx on non Secure ch
ssd
NEVADA
can you set up a xts radio not to tx on non Secure ch the xts 2500? thanks vince
XTS3000
You can strap channels secure, so there is no way it will transmit in the clear.
ssd
NEVADA
ok no way to set it to not tx with out it being a encrypted ch only
XTS3000
You can still receive "clear" traffic no problem.
If you strap the channel secure only, it will not let you transmit in the clear.
Maybe I don't understand your question or what your trying to do.......
RocketNJ
Pequannock, NJ
I think he doesn't want it to tx at all on non-encrypted channels. Why not just program those non-encrypted channel for rx only?
Simple enough
ssd
NEVADA
trunking i want to put some fd and pd ch in are security radios we have the right to be on the System.
Grog
Banned
West of Charlotte NC
Just because you have the "right" to be on the system does nto mean you should be programming your radios for TGs you are not meant to have.
ssd
NEVADA
i am not the guy the taks the radios dos i just want to see if he would do it. if o seid how to do it
SkipSanders
Silent Key
Realize that if they CATCH you with any talkgroup programmed into their radios that you aren't authorized to have in there... it's bye-bye for you. They install what they want you to have, no more. There are plenty of groups in police systems that the beat units are not 'allowed' to have in their radios, for example.
You are intended to be listening to specific talkgroups while working, not 'wandering around' elsewhere. There will be a system record that you were on the other group, and yes, you have to transmit to get on it, with a real, legit on-the-system radio. When you rotate that channel selector, your radio transmits, says 'I'm on this talk group now', and the central controller acknowledges and affiliates you with that group. (among others). There is a log of every channel you affiliate with, and when.
zz0468
Banned
Again, please. Only, this time in English.
N4DES
0598 Czar
South FL
If you program a radio, even a legal one, with a parameter that isn't allowed for that particular talk-group is a red flag for the system administrator. I should know because I do get those alerts daily and is justification to disable the radio whether there is an agreement in force of not because if comes across as a rogue radio.
If your agency has an agreement to be a legal user this action will probably violate that agreement. Best for you to use a scanner to monitor these talk-groups.
RolnCode3
Sacramento/Bay Area, CA
There are several users of the same radio system on RR. Some work in communications sections, others know radio techs personally.
The warning has been given. If it went somewhere it's not supposed to, there are numerous people that could take care of it. It sounds like SSD has been given plenty of advisement and it's up to him how to proceed.
ssd
NEVADA
well i did not know that till now i will just keep my PSR-500 at work. thanks for all your help guys.
kb9sxk
Southern Indiana
Well played. I am an offical user on a system. It is easier to have a scanner handy that risk your job.
