Xts scan
I have an xts that when i press the scan button it does a double tone like a “boo-deep” but our work radios only do a single beep when i press scan, both are xts 2500’s
Sorry this wasnt supposed to be a comment post but a question of why its different between radios which are both conventional
cmjonesinc
Could be that button is programmed for something besides scan. Could be it is a scan button but a scan list was never setup for that channel or at all. Just because it's the scan button on one radio doesn't mean others are the same. There's a lot of functions that can be assigned to any of the buttons including not being assigned to do anything at all.
No, it is both set up for scan. They both show the scan symbol and actively scan when it is pressed
cmjonesinc
Perhaps nothing is programmed to the scan list. I haven't programmed a XTS is a long time so I don't really remember the details on the "beep-boops".
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
Also - if your radio has old firmware - even if Scan Alert Tone Enabled is checked - it still won’t work.
OnYourSix
Hold down the scan button and it may take you into scan programming.
