XTS triple beep permit tone
JackRoberts23
Was Justin Schmidt
Can anyone help me suet up the triple beep talk permit tone for my XTS 5000?
I went to multiple YouTube videos, and I have copied everything they did, but no luck.
Any help is appreciated
mbnv992
AZ
More info is needed. Talk permit tone on an analog frequency ? Trunked ? P25 digital ? Encrypted ?
JackRoberts23
Was Justin Schmidt
Sorry my bad. For an analog channel. I know there is a way to get it, just can’t find it
ElroyJetson
The triple beep is the talk permit tone in trunked mode ONLY.
To the absolute best of my knowledge, which is fairly deep with regard to the venerable 5K, you're not going to get it in any other mode of operation. I'd know, I spent plenty of time seeking that myself. It's just not possible if you're not registered to a trunked system.
Be happy with the clear TX alert tone which you can enable.
JackRoberts23
Was Justin Schmidt
Ok. Thanks for the help.
For a trunked system, I can’t seem to get a system key. How can I obtain one (legally)? I went to the website hacker russian or whatever it’s called, and many people claim to have success with it, but it led me to a nude website.
Any ideas?
ElroyJetson
That's a subject that people are not going to discuss much, at least not openly. Forget getting it legally, you can't. But everybody's got the key generator. It's the radio geek equivalent of jaywalking. Illegal but nobody cares if you don't get run over.
Any ideas?
Be happy with that.
Don't mess with trunked radio systems unless you know for sure what you are doing, are 100% confident in your abilities, and are 100% willing to take the heat if you get it wrong. Accessing someone else's trunked system just to get the cool sounds isn't a good reason. Doing it wrong can take resources away from first responders and risk lives.
Yes, it can be done, but you need to do it right. There's a real good reason why we usually tell people to just get a scanner.
rich1125
https://www.youtube.com/@ourthinlines1404 I FOUND THIS FOR YOU I HOPE IT HELPS ARE YOU ENCRYPTTION ENABLED IF SO WATCH THIS VIDEO YOU MUST HAVE DVRS ENABLED ON YOUR RADIO , SORRY FOR THE CAPS LOCK MY KEYBOARD IS BROKE HOPE IT HELPS,
rich1125
Ok. For a second I thought you were yelling at me
no i fixed that keyboard sorry for that, much like you im fairly new also but i happened too see this post so i wanted to send link to you . i hope it worked out for you but if it did not i will keep looking you can also e-mail that guy on you tube he will help you out also like these guys do here .
Giddyuptd
Here and there
Any ideas?
The system administrator.
If you're talking about conventional for gmrs or murs and so on you'd need to have DVRs option enabled and trick the radio to look for a DVRs then enable talk around. This isn't ideal as it'll attempt to find a vehicle repeater and delay before going into talk around which gives the tpt tone. Morely useless.
As for systems you need to be authorized and let the designated shop touch it regardless who owns it.
Giddyuptd
Here and there
Be happy with that.
Why LLA is a real thing popping up on systems now. Several I know of are in works to implement it.
