XTS-XTL in CPS
Does anyone have any suggestions for how to easily program an XTL5000 identically to how an XTS5000? I know cloning isn’t an option because the two radios are different models entirely. Additionally, I’m wondering why on my XTS I am receiving a channel (that is very far away) but on my XTL the RX light isn’t even lighting up. Thanks so much!
Giddyuptd
Here and there
One issue that may explain the rx of a distant repeater is location radio is at, skip, mostly likely needs to be tuned and aligned plus the antenna being used should be aligned properly.
Giddyuptd
Here and there
I like Mikes idea better. While importing does work I've just noticed things or minor issues with it which I never been a fan of.
ME801
NV
Drop and drag has worked better for me that importing.
Your radio probably needs to be aligned on a service monitor all other things being equal.
How do I:
A) drag and drop
B) align and tune
Thank you all so very much
Figured out the drag drop; I’m still having trouble with reception. My XTS vhf with the wide band antenna is picking up the repeater but my XTL isn’t. Got the XTL for the purpose of it being able to transmit and receive at more power and have a better antenna.
KG4INW
Midlothian, VA
To perform an alignment you need a calibrated service monitor ($$$) and the ASTRO 25 Tuner software along with the requisite know-how (and known good cabling). You check your antenna/feedline with a good wattmeter or antenna analyzer. Use a multimeter to check for shorts, opens. Might be best to have a professional radio shop check everything out for you if you're not comfortable with any of that.
KG4INW
Midlothian, VA
In light of rescue121's generous offer, I should amend my suggestion by adding ...or find someone in a local radio club who's willing to help you out.
If you were near me, I could do all of that for you for free.
I very much appreciate the generosity. Interestingly enough I drove 100 yards north and reception was absolutely outstanding. Not sure why my handheld works perfectly at home and the XTL doesn’t.
rescue161
KE4FHH
Hubert, NC
Either front-end overload from nearby transmitter that the mobile was picking up that the handheld was not, or the mobile needs an alignment. There is probably someone close to you that can help you out or maybe even someone with a service monitor that can align it for you. They may even let you watch and can teach you as they go. That's what I like to do. Ham clubs used to be a decent place to ask for help, but it's becoming more difficult to find hams that a) have the equipment and b) know what they are doing.
Sounds good! I will make sure to do that; it would be a great skill to learn.
ME801
NV
Starting to sound like your radio could benefit from an alignment. I send mine out every year. It's cheap insurance for a quality radio.
N1GTL
CT
I didn't see it mentioned but if you do a top node drag and drop between a portable and mobile, your power settings will be out of whack. You have to go back and set them correctly.
MTS2000des
5B2_BEE00 Czar
that is the case with APX, but IIRC the XTL/XTS CPS won't touch those (and other fields too, like menu items) between the two. None the less, that is a quick fix but it wouldn't affect the user's RX sensitivity the way it's described.
So to everyone, I took it up to NH this weekend and it worked perfectly. As soon as I went south of the border the portable worked and the mobile didn’t.
