XTS1500 RSM Emergency Button
cackis
Orange County & Bronx NY
Good Afternoon All,
Quick question about using the RMN5038A remote speaker mic on a XTS1500. I have the radio programmed with emergency enabled and it works fine with either the button on the RSM or the radio. For some reason when I try to reset the radio to take it out of emergency mode, if I hit the emergency button on the radio (long depress) it resets the radio but it doesn't work if I try to reset the radio using the emergency button on the RSM. I tried a few different settings in the cps but as of now no luck. Any ideas? Thanks in advance.
Jim
esfd283
We use that same set up here and I believe that is the way it has to be. We have the same issue and we were told by the radio vendor that emergencies have to be reset at the radio itself.
cackis
Oh well. If that is the only way to set it up we'll have to live with it. It would be nice to not have to reach for your radio under your bunker coat if you hit the button by accident. Thanks for the info.
