Xts1500
Thorny41587
Holland, OH
I currently have a CP200 programed to PS freq. that I listen to. My county will be going digital within the next year. Do they still make the XTS1500? And if so is it going to be the cheapest digital capable radio Motorola has? Also, can I have it programed for a TRS system?
W0JJK
It is still made and yes it can be programed to do a Digital Trunking System by the Sytem Adminstration of that system.
W0JJK
Thorny41587
Holland, OH
O. So an outside like myself would not be able to do so, like you can with current freqs and pl tones?
W0JJK
No, a Motorola Based Trunking radio need a system key to program a system into a radio. You can not add a system without a system key for that system. Only system administrators and radio shops who program radios on that system have that system key legally.
If you want program yourself, your best bet is a scanner. You can program that easier and scan more then 10 talkgroups which is all the motorola would do on a Trunking system.
I don't own a digital scanner but others may recommend one if you want to got that route.
Good Luck,
W0JJK
Colin9690
Delaware County
Lewis Center, OH
Yeah, buy a digital scanner like the PRO-2096/96, BCD996T, BCD396T, etc. It will save you alot of trouble in the long run.
tuckerone
Fairborn, Ohio
So with all of the above said, I would have to think that since five people in Michigan, one former State employee, a four other's he had programmed Trunked Radio's for are either in jail or getting ready to head that way, you probably would not only be violating Motorola Licensing laws, but also homeland security. Get a scanner!
DewAddict
Michigan
From my experiences here in Michigan, My pro-96 receives better than an FD issued XTS5000 on the APCO-25 9600 baud system. Even if you find a way to get an XTS1500 programmed, you couldn't TX with it and have spent big $$$$ on what is basically an equivalent of a "scanner" that you could have gotten for $400.00 +/- $$$.
Just my opinion as others have said.
Rob
N4DES
Retired 0598 Czar ÆS Ø
South FL
X1536 said:
Do they still make the XTS1500? ?
Yes it is available in VHF, UHF, and 800
Probably, it's sub $1500.00 to most agencies and I doubt it will go any lower
Have to ask the System Admin. that question. Anything can be programmed with his blessing.
medic611
NC Foothills
Here are my 2 cents , first if you don't belong to a public safety agency why do u need a radio programmed ? 2nd and most importantly are you willing to risk your " new " radio to become a paperweight all so that you can listen ?
bigray246
Toms River NJ
OK you guys talked me into getting a digital scanner instead of an E-bay Motorola Saber. My city just went to a 6 channel Motorola UHF digital trunking system. Now I need a base freq.& offset, how does one obtain this info? Is there a way to calculate this info?
EFjohnsonVHF
Banned
USA
Look in the rr database for your state/county/system.
WayneH
Forums Veteran
Super Moderator
Your master site
Please don't thread hijack. Thanks.
If the data is not in the database please search the Motorola trunking forum. It's a pretty common question. You can also look in the Wiki.
