XTS2500 700mHz Help
dkshell
Pulaski, VA
Hey guys, I'm having problems getting the 700mHz interop freqs programmed into my XTS2500. Whenever I put in a freq in the below 851mHz range, the field shows invalid (lined with red highlighting). Can anyone offer some opinions on this??
MTS2000des
5B2_BEE00 Czar
"TX Opt Transmit Dev" and "Tx Opt Transmit Dev T/A" are set to 2.5KHz for the 700 channels correct? if so, the red box should disappear.
700MHz requires narrowband deviation. if it's set to 5KHz or 4KHz, you'll get the invalid fields indicator.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Type those fields into the Help file. It will show exactly in the CPS where they're located.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Click on Help and then index.
Type TX OPT DEV into the search box and it's definition and location in the CPS will pop up.
The help files in Motorola CPS are actually very useful.
