Xts2500 800mhz question
firebell9137
Hi everyone. Does the xts2500 receive simulcast? Just wanna know before i buy a trunking 700/800mhz radio.
Giddyuptd
Here and there
Without answering or commenting on the majority of things with trunking yes with proper flash code set it will do phase 1 and handles simulcast. I'll leave the rest of the commentary to whomever.
chrismol1
P25 TruCking!
yes digital simulcast on both conventional and trunking as long as the Digital Modulator Type is set to CQPSK
Thunderknight
Bletchley Park
  • Like
Reactions: fog
buddrousa
The short question is.
Are you authorized to be on or use the system?
If you are you will be better off getting a radio from the Administrator of the SYSTEM.
A DYI setup is not for beginners.
firebell9137
chrismol1
P25 TruCking!
You will not get a good response to a basic question such as that. Programming a radio for NAS is not something that is a casual endeavor to casual questions like that, you will not be taken seriously
When I programmed my first radio I started with scanning the conventional voice channels for over a month before I dived into the real thing so I had a 100% understanding what I was doing and where things went. I used the CPS help files to understand each thing I was about to screw with before I properly screwed with it. There has been similar NAS postings recently thru the past few pages
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Ok thanks for the warning. I will not buy one then.
Do your research first. Watch the videos, read the write ups and once your familiar with the process, then come back and ask reasonable questions. Too many people are buying these radios and expect someone will be there to walk them through the process step by step.
