XTS2500 Channels Go "Deaf" With PL ... suggestions?
sefrischling
Public Information Officer
New London, CT
A VHF XTS2500 is having some odd PL issues that I cannot figure out.
Certain frequencies work perfectly in CSQ, but will not receive with the PL programmed in. Hold down monitor you can hear, or just leave it programmed in CSQ you can hear, but program in the PL and the channels go deaf. It is not every frequency, most work as they are supposed to with frequency and PL, and I can’t figure out any pattern this this issue.
Before you say “is the PL right?” or “check the PL” … these frequencies and PLs work just fine in XTS 3000, Astro Saber and even UV-5R radios. It is just this one XTS2500.
Any suggestions? It is driving me nuts!
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
Just one major thing to look at. Are the channels set for 2.5kHz spacing or 5.0kHz? Even though you might not be TRANSMITTING on them, the receive still looks for this. I had the same issue on my XTS5000, and after changing to the "narrowband" of 2.5kHz spacing, everything worked fine.
Just something to look at.
Regards,
-Frank C.
RKG
Boston, MA
Regards,
-Frank C.
Concur. If your Rx radio is set for 5 kHz and the TX radio is set for 2.5 kHz, the Rx radio will see the PL at half nominal deviation, which may be too low to be called valid.
sefrischling
New London, CT
Just one major thing to look at. Are the channels set for 2.5kHz spacing or 5.0kHz? Even though you might not be TRANSMITTING on them, the receive still looks for this. I had the same issue on my XTS5000, and after changing to the "narrowband" of 2.5kHz spacing, everything worked fine. .
Thanks, I'll go take a look and see what these channels are set for. Might explain why one of those channels works just fine in Zone 2 and Zone 15, but not in Zone 1.
sefrischling
New London, CT
OK, when I go to change the spacing I get the "glasses" preventing me from making any changes in the CPS. Is there a step I am missing?
I pulled up the CPS for the Astro Saber/XTS 3000 ... which I know is completely different software, and I didn't encounter this. Went back to the XTS2500 CPS and I can't seem to get it to allow the change.
sefrischling
New London, CT
What section are you in? You should be able to change it in the Zone Channel Assignment.
That is where I am in, and when I got to Channel 2, Channel 3, Channel 9 in Zone 1 it will not allow me to change the spacing. I can change the freq, the channel name, the PL (other channel's NAC), but I cannot change space for any channels.
sefrischling
New London, CT
You know ... it is only in zones where the channel is RX only it is an issue, the TX ones work just fine. Back home to the laptop and cable I go!
sefrischling
New London, CT
Switched to Narrow ... went to upload and got a FAIL 01/82 that I cannot clear.
Oh yippee. I'm guessing it a radio issue.
GTR8000
NY/NJ Database Guy
BEE00
Sounds like the radio was at firmware R11, which was a disaster.
Google "XTS FAIL 01/82" for the depressing details.
sefrischling
New London, CT
Please tell me you saved the codeplug before you exited cps. If so, you should still be able to identify the firmware, sn, flashcode, etc through the Radio Information tab for that codeplug.
I did, I'll grab that info when I get back to that laptop
