XTS2500 FPP With CPS
jtech48
OVB
I recently purchased a Motorola XTS 2500 from an ebay seller with tags. Radio Came WIth FPP, Flash COde is 520001-001304-7, Firmware is 9.00.28 and DSP is 15.00.05. I took the radio to a friend who is attempting to re-program it to change abc toggle switch, remove zones and is unable to modify it. He cant even modify channels, he is Using Astro 25 cps v.16. Has anyone come across this issue, any solutions?. Any Help Is Highly Appreciated
XTS3000
Can you even read the radio's codeplug? Sounds like the previous owner may have locked down the radio with ASK. Without the ASK, you may not be able to reprogram certain CPS fields.
jtech48
OVB
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; ADR6400L 4G Build/GRJ22) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Yes he can read it and he also saved it
N4DES
Retired 0598 Czar ÆS Ø
South FL
If you can read it and save it that means that it isn't password protected, but like XTS say's, if the radio was programmed with an Advanced System Key that was programmed for things like Write Protect Enabled then you won't be able to do anything with it without an ASK to include programming conventional fields or changing user parameters. It is a very powerful feature Motorola now has and there is no way to tell if a radio has been touched by one until you attempt to read it or program with CPS.
station32
Augusta Me
The only way to fix this that i know of will take about five mins with the depot software.
jtech48
OVB
It works just enough to receive only and gmrs so its not bad at all. Thank you all for the replies, your all very helpful
jtech48
OVB
a little off topic but opened up my MOL account and accepted the license agreement and i can now see the software on my account, the only thing is that when I go to purchase it, it asks for purchase order no. and i have no idea where to find or how to get it, do i have to contact MOT for that?
askdaniel1
I have a similar radio, and each channel in each zone is a unique conventional personality, al lthe way to the maximum number of channels and zones. It is pretty much impossible to do things like move a channel, or delete it.
I haven't ever had any problems editing the frequency, tone, or modes, but it seems that each zone is locked to 16 channels, and each possible zone is created and full of 16 channels.
Maybe the person trying to edit the code is just trying to do things like move or delete channels?
rc50won
Plantation, FL
Because it's an FPP radio, you cannot arbitrarily move or change Zones. Also do not remove the FPP flag from a Zone unless its the last Zone. Doing so will erase all Zones after it.
Marshall
jtech48
OVB
I Just Wanted there to be no zones and just all channels open but its ok how it is now. I have my 5000 the way i wanted it
