XTS2500 Model II Scan Lists
Thezoo251
I am wondering if it is possible to program my XTS2500 to scan different conventional frequencies when I switch zones?
The radio is a Model II. It does not have a front keypad therefore it's not field programmable.
Thanks.
Project25_MASTR
Something about Vikings, Raiders and 1923...
Texas
Yes, but what are you really wanting to do?
Do you want it to automatically begin scanning whenever you changes zones? Do you want it to scan from a different list which is different for each channel?
IAmSixNine
Dallas, TX
Model 2 does have buttons on the front and you can use those to have a user selectable scan list.
Unless you mean a model 1.5 which has front display and no buttons on front.
Thezoo251
It's a unique radio. It's a model II but doesn't have the front buttons.
I'd like it to scan everything in a specific zone when I switch zones but I don't know how to get it to do that.
Thezoo251
The problem
I have figured out in the CPS how to put the radio into scan program mode. I programmed it to selection knob "C".
The problem I am having is finding the right button (purple) to program to have the radio select or de-select a specific frequency to scan when in the program mode. The purple button works to do the same thing on our XTS5000's at my work.
drayd48
You could just select in your conventional personality for the radio to go into automatic scan and then it would go scanning automatically. Should be under the SCAN tab and then just select your scan list.
