XTS2500 multiple scan lists
E5911
the lower desert
XTS2500 VHF
Ok so first, I looked all over including the forums, and found how to set up one scan list, but not multiple ones.
I frequently travel to Different areas around where I live , and have zones to monitor/tx for various locations. I want scan lists for each.
I have Conventional personalities for each zone. So 8 different zones 8 personalities, 8 different scan lists. but when I go to scan I check the scan list by holding the 'scan' button and I'm back at scan list 1.
Also thought I could review and add or delete members of each scan list assuming I'm in the right zone with the right personality for the scan list.
No NAS, conventional vhf frequencies here. If someone would be willing to review the code plug file offline, that would work too.
Any help appreciated.
FFPM571
Nashvillle
If you have the areas you listen to in zones attach a scan list to that zone.. Zone 1 SL 1 Zone 2 SL 2 you can select zones and channels if you have it set to operator select
