XTS2500 P25 Help
dkshell
Pulaski, VA
Okay, so we're changing one of our radios from an XTS5000 to XTS2500. All of the SmartZone stuff works perfectly, but the P25 system won't work. It reads "SYS REG RFSD." The Unit ID in this radio is the same as the 5000 that is being decomissioned. What's the problem? Side by side, all setting are the same.
RKG
Boston, MA
There are umpteen more parameters that have to be set properly for an 9600 baud system than for a 3600 baud system, and I suspect one or more of them has an unperceived error.
For openers, check that the site numbers are correct for the site (or sites) for which your radio is programmed to operate. (Just a guess.)
dkshell
Pulaski, VA
Well, apparently it was the Two Units with the same ID thing. What I don't understand is why even though the old radio is off, the new one still wouldn't work with the same ID.
