xts2500 screen not working
dagwag77
Boston Metro Area
Ok, so I slipped on the ice (lovely Boston weather) and slid butt first down a set of stairs, with my trusty xts2500 on my belt, which got dragged along for the ride. Surprisingly, no noticable scratches on the case, but my screen is all screwy now. When I turn it on, I just get a blank lit (Greenish) screen. If I hit the zone button that line of text will appear (perfect quality). If I start to change channels now or press other buttons or change the ABC switch I can get most everything to appear on the screen, but not all at once. Sometimes text will appear and not disappear, sometimes text wont appear - its quite screwy. I put a new codeplug on it, and nada. Right now its showing me the time (top left) and the channel, no zone, no scan symbol, my name is usually on the line under the channel and its not there, sometimes BATT shows up, sometimes SCAN shows up (buttons)....quite odd... If you think pics will help I'll post 'em.
Any suggestions, short of taking it to Moto dealer?
Thanks,
Dave
WayneH
Forums Veteran
Super Moderator
Your master site
The screens are not difficult to replace if you can locate a replacement screen. They're on ebay every once and a while. I think there are certain ones that are model specific so beware.
If you take it to a dealer they'll rape you on parts and labor. I purchased a 5000 ModIII with all electronics for 100 or 150 on Batlabs. Try a wanted over there if ebay doesn't have anything.
Josh
Auburn Hills, Michigan
You could try to dismantle the radio and see if the flex cable going from the display to the radio's control board hasn't been knocked loose.
Other than that, a new display can be purchased from a dealer and installed by you for about $85 the last time I had to buy one. If you have the part number (located on the display board somewhere) you can buy it from a source like myradiomall.com and avoid some hassle.
-Josh
dagwag77
Boston Metro Area
Take your palm and smack the hell out of it.
No really, I'm not kidding.
OK - what the hell right? I gave it a shot. So i'm whacking my radios screen with my palm for 30 seconds and start asking myself if I've lost my mind. Then I turn my radio on still in WTF mode, and the screen is back to normal. The damn thing works again!
Thanks for the tip ILMRadioMan, it worked! I owe you
robertpearsall
Edison, NJ
XTS2500 Display
I had a display that was cutting in and out on my 2500i i found if i pressed on the key pad on the left side just below the display it worked fine so I opened the radio and the flex cable between the display and the key pad was lose. I unpluged it and pluged it back in and have had no problems since hope this helps
dagwag77
Boston Metro Area
So its still possible the flex or something is loose. I've never opened one of these suckers up, anyone have some instructions?
Thanks,
Dave
n3obl
ØAES-1024
PA
find someone over at batboard and order one. should cost no more than 80. easy to replace. will need tool to open xts housing.
Frank
dagwag77
Boston Metro Area
OK - so the screens working well now, but the volume on my radio is horrible now. I guess it has something to do with the impact from the fall? Again, any ideas? (I tried hitting the speaker, didnt work...)
Dave
ILMRadioMan
The road to no where.
haha.
Yea violence only works so much ;)
You may just need to dive in and open it up to see if something is loose.
Or put on an external speaker (mic) of some sort.
dagwag77
Boston Metro Area
Well, my RSM is why it took so long for me to realize the internal speaker started sucking...
And now I've been playing with the CPS to try and figure out how to set up user selectable PLs (MPLs) and its bugging me, as its not working!
Edit:I think I've figured it out, the radio has v5 firmware and MPL didnt "work" until v6 firmware....need to get the radio upgraded...
gatekeep
FAIL 01/93
New York, NY
R05.xx.xx firmware is older than dirt... R12.00.01 or so is the latest HOST/DSP for an XTS2500.
You should contact a local radio shop or MSS to have it upgraded. Last I checked its $75 for the flash and labor (I *think* don't quote me on it), if it has to goto /\/\ well flat-rate fee's aren't fun.
dagwag77
Boston Metro Area
Yea, I know its way past due to update the firmware on the radio, but I just hate giving mother /\/\ more money than its worth....
*cough* *cough* if theres anyone in the boston area that can hook me up, shoot me a PM or IM!
