Xts2500 trunking question
firebell9137
Hi. Does the motorola xts2500 700/800mhz radio do talkgroups? I was going to use it for SLATER St Louis, Missouri digital trunking freqs. H46UCF9PW6AN is the model #
firebell9137
If you have to ask the original question this radio is not for you...
I read up on advance system keys. Learn something new everyday. Lol. Doesnt Uniden have a scanner that does this? (I cant afford one yet). How does it do the talkgroups and the 800mhz control channels without the ASK? Also what is M6512?
FFPM571
Nashvillle
A properly programmed scanner will do everything you need An ASK locks the radio from having any unauthorized changes made to the programming. Scanners do not have any ASK
FFPM571
Nashvillle
Yes it is possible... I don't think the software involved has the same pedigree as the one that shal not be spoken of...
W0JJK
I do this from the regular CPS before we surplus radios. These are the steps I use. I have used this on XTS5000 and XTL5000.
Step 1-Load Advance System Key
Step 2-Read Radio
Step 3-Tools-Password-Read/Write Password, this were you remove code plug passcode if used.
Step 4-Modify Permissions-Uncheck all three boxes, Click OK
Step 5-Tools-Set Owner System ID
Key Type-Advanced System Key
Owner System ID- select correct key number of the system.
Click-Disable Write Protection
Click Set
When this process is done, Close CPS, remove Advanced Key from Computer.
Step 6-Open CPS, Load Soft Keys that match the systems in radio. Read the radio.
Step 7-Add a new system with default key 1, delete old trunked systems and their personalities. Add new Personality for system 1.
Step 8-Add a new conventional system, delete the old conventional system and personality.
Step 9-Delete all the zones except 1, change it to have 1 channel of the new conventional system
Step 10-Make sure you turn off Infinite Key Retention, if radio has secure enabled.
Step 11-Write radio, now is should be conventional only programmed with no Radio System information or Encryption keys. Anyone can program the radios now, for conventional or different trunked system.
FFPM571
Nashvillle
that is all fine and dandy but without an ASK he cant do any of it. The one I am talking about was to fix a different issue and just happened to resolve the whole ASK issue as a side note
APX7500X2
NY/CT
Find CpFixFilePackage_ASK and it removes the ASK from XTS/XTL radios and you can start from scratch
IAmSixNine
Dallas, TX
Save your money and get an SDS100 ( if your area has simulcast systems) or BCD436 or a Unication G4.
