XTS2500I Not Powering On
teslabolt77
Noticed some funky display issues during a short period of time while riding in the truck. Just had it sitting in the cupholder. The screen flashed some strange menu stuff and then the screen display inverted. WTH?
Now it won't even power up. No red light on top, no flash of the display. Put the battery by itself in the charger and it is green and good to go. Any thoughts? I have heard the flex cable to the display board is weak on these. Could it be that?
K2NEC
I guess it's possible that since it has been in the cup holder and riding in your truck it could have damaged or loosened something inside the radio. I would take it to get checked out. I wouldn't open it unless you absolutely know what you are doing.
marcotor
I ♥ÆS Ø
Sunny SoCal
Anything is possible. What kind of channel was the radio parked on? Analog/P25/Encrypted/Trunked? Scanning or not?
wgbecks
NE Wisconsin
It doesn't sound good but I'd suggest that you try reading the codeplug to see if your get a communications fail or not. I'd also try another battery just to be absolutely sure its good, especially if its an Impres type battery.
rescue161
KE4FHH
Hubert, NC
Loose flex. See it all the time. There are a couple of flexes that can loosen due to rough use.
