Xts3000 Astro TX beep?
Will001
SC
Is there a way to get my XTS3K to emit a "beep" before I transmit on an Astro-enabled conventional channel? I know about the clear tx beep in the encryption section of the software, but I don't have any encryption in the radio. Is there any way to get a beep, but not the clear vs encrypted beep?
sfd119
MDC side tones may do it but I'm not sure with a 3000.
Best option is the TX Clear Beep. I believe you can still turn Encryption on in the settings by selecting Hardware encryption but it will present a FAIL code each time you boot up the radio (as there is no hardware installed).
Will001
SC
Ok thanks, I forgot about the MDC sidetone. It sounds like I got to go turn on the hardware section in the CPS
Project25_MASTR
TX-COMU
Texas
Also if you have software adp, you could go about it that way as well.
