XTS3000 Audio
Devils4121
My XTS3000 has extreamly low audio when it receives, does anyone know of away to fix this?
fineshot1
NJ USA (Republic of NJ)
My XTS3000 has extreamly low audio when it receives, does anyone know of away to fix this? Thanks
Do you have a speaker/mic for it? If so is the audio also low with the s/mic? If not then its most likely a bad or dying speaker and needs to be replaced. If so then its an internal problem and needs to sent to a moto authorized service center or moto elpaso.
radiowaves1
Banned
On the RF wave!
Suggestion
In the CPS software, open the "radio wide" settings then click on "Audio gain" tab. You can adjust it from there. otherwise, it may in deed be the speaker that is dying. Hope this helps.
Mike
Devils4121
Mike
So when I goto "audio gain" what should I select to make the audio louder?
