XTS3000 Encryption
Devilz311
NJ
Quick question: does a XTS3000 need to be flashed for hardware encryption, or would I just be able to purchase an encryption module and install it?
fineshot1
NJ USA (Republic of NJ)
I am pretty sure you can just install the module, but a lot depends on your
firmware. I think if it is earlier firmware you may have to get a firmware refresh
in order for the module to work.
bezking
On the Road
Here's how this goes:
If you have the UCM installed WITH Hardware Multikey in the flash, you get up to 16 (I think) keys that you can fill.
If you have the UCM installed WITHOUT any crypto in the flash you can only use ONE key even if the the UCM has multiple algorithms.
hth
gary123
hth
This is correct.
dont forget to confirm the UCM you need, some modules do multiple modes some only do one. Your keyloader will load the keys for the mode (modes) it supports. If you have a single key then the radio will automatically select this key even if it is a multimode module.
